TONEY
hey all
well it all started 3 months ago when i picked my 3rd k11 up
the firsts thing to go on was wheels, full janspeed. and induction kit
the next weekend was shocks and -35mm springs and a set of seats with harnesses along with the interior coming out as well
then it decided to started to have a drinking problem
it started smoking alot and was useing 1l in 3 days and none of that was leeking
so a new engine me think
i set out to get a primera almera or sunny
after a week searching i got 1 for £100 had been bashed up the ass
then the work started taking the engine out of it
12 hours later both engines were out and cleaned up
this was the rad on the primera
i first took the water pump pulley off as i kno this would get in the way
mounted the micra engine mount (left hand side) on to the engine and fitted the primera crossmember in place once i had it all lined up i marked were the leg had to be cut to house the water pump pulley and the gearbox mount marked up
this is how i got round the problem of the water pump
then the engine went back in
in went the ecu
how tight
all plumbed in with a civic type r rad
then the day came it started straight up and it only had the manifold on (very noisy)
at the moment im waiting for the drive shafts 2 be shortened and a down pipe to be make up then its mot time
while ive been waiting for them 2 be finished i started on the dash
that all for now will up date soon when back together
in went the ecu
how tight
