G_Man
Well had my MOT and it failed on the following things....
Number Plate light inoperative
N/S Head Light Low Aim
N/S Bottom Ball joint - no locking device
O/S Outer CV Boot split
Steering Rack gaitor fouling fuel pipe clip
Handbrake lever insecure
Load sensor valve inoperative
O/S Front brake caliper carrier bolt has no lock device fitted and bolt loose
N/S Parking Brake + service brake low effort
Rear brakes do not increase and de-crease at same rate (70% inbalance)
N/S Front seat belt insecure :S
N/S Wind Screen washer inoperative
Rear view mirror O/S can not be positioned to view rear
Lambda high 1.08
Exhaust insecure + silencer is of such a type that the noise emitted from the vehicle is clearly unreasonably above the level expected from a sililar vehicle with a silencer in average condition.
Jus copied all of that from the MOT sheet, will try fix most of it asap :down:
Lambda high 1.08
