Shero
so, the thing still aint running rite.
basically these are the symtomz....
The car will now start no problem and will sit at idle perfectly, in neutral it will rev up nice and i can hold it up at the red, come off and it goes back and sits at idle fine. (which never used to happen.)
Ive left it running for half hours and its perfect.
But.. when i go to drive it it just splutters and dies. i only get mabey 30 yards and it looses all engine power.
So, i jacked it up and ran it on the axel stands, i ran it for about an hour with no problem, up all the gears and sat about 3500 rpm in all gears. no problem!
So, its something when its under load thats killing it, ive been pointed to the cam shaft sensor. What should i be looking for in this, and is it fixable or i need a nu one??
Also got some 1600 injecters to swap in but sould i leav them first? although i also think it could be the injecters blocked??
I need help, i just want to drive the thing. cheers for any advice.
