Microstar OC218 Oil Filter
Asked my local motor factor for an oil filter today for my nissan micra 2002. Before I had a champion c141. This time I got a cheaper Microstar OC218 oil filter made in austria. I haven't opened the box yet, just wondered if anyone knows if this will fit as I can't find anything online about it.
Well, I can slightly open the box without breaking the seal, so I can compare the thread sizes visually before opening it, if that makes sense.
Well, I put it on the car and it seems to fit okay. The oil was leaking around the drain plug. I found out why. A small piece of grit got trapped under the copper washer during the last oil change and when I tightened up the plug, the grit cut a nice groove all the way around the washer.
