Micra K13 Lower/Firmer Suspension info needed
Hi there! :)
I got a Nissan Micra K13 1.2 x-cvt as a present about 6 months ago. o_O Weird present, aye?
Now, after seeing some tuned K13, I decided that a suspension upgrade might cheer the car up, as the factory settings are too soft and there is massive body roll.
My question is: what suspension model fits the Micra K13? I do not mind what type it is. It might be simple as dampers+shocks or coilovers. I've also seen some springs that go over the factory shocks: http://eibach.lowering-springs.com/...ro-Kit-E10-63-023-01-22_16588_56_539_3017.jsp. Are they any good? Or it will make the ride worst?
I might go with the eibach. The reviews say that the ride is better on the eibach springs. I wish there were more companies to produce sport shocks (dampers) also.
BC racing ones - not sure if these are any good?
Eibach - just for lowering
Tien look best but think purpose is lowering/street look more than suspension improvement?- also pricey
Fitting side skirts + front spoiler (available from Nissan) would make car look lower if that's all your after?
Sent from BlackBerry 9790 using Tapatalk
Found 2 other suppliers of coilovers look at www.race.fi seem to list under Micra K13 type 1 and type 2 with different products inc street, race and high travel rally gravel. If not a mistake look very good but pricey.
Also www.cusco.co.jp look good
Thank you! It's not all about street looks, because the stock set-up is very hard on straights (you can feel every imperfection) but very soft on cornering (lot of body roll). It will also improve the handling :cool: I'll check the sites and I'll post my decision. :D
