Couple of years ago I got 2nd hand alloys from scrappy off a n14 almera,had to grind them a bit to fit,taking them off took a chunk off one of the rear wheel center bores. Looking on ebay a cheaper way of replacing would be a clio hub as would prefer a newer one so get good life out the wheel bearing too. Am I right thinking the clio hub is identical to micra k12? Its only the outer of the hub I'd use.
