Micra k12 locking problems
Hi
So I’ve got a k12 micra sport 2008 central locking just stopped working couple months back and the car ending up being parked up for a bit without fixing. Have changed to new batteries and even got a mate to check the key is still working and giving out a signal.
The car will lock from the button inside at handbrake, will lock the passenger door with the key ( only passenger door locks )
Have tried the key in ignition sequence but not even getting the double flash
Have also checked all 3 fuse boxes can’t seem to see a located central locking fuse
So here I am, please any suggestions where to look or what to do would be greatly appreciated
Hi, have you looked at the instrument cluster for the immobiliser light flashing red.
Next is this a key or keyless fob?
And probably should check the fuse
F6 10A
Air condition alarm and central locking are on that fuse so if you have a problem with one of those items probably you should check air conditioning and alarm if installed..
Ps the location is next to the steering wheel and not on passenger side for a UK righthand drive vehicle.
The plastic cover back has the fuse locations printed onto a diagram
