For the rear hub nut I bought a 30mm socket from silverline.
To replace rear bearings when required.
I have not used yet but one would assume front and rear hub nut is same size.
Its probably a 32mm I would measure and see to be sure. And check the size of a replacement hubnut online to see what size as far as I can see in that case is 30mm.
Only had to get one because my set only goes up to a 28mm.
Axle Nut, drive shaft - Buy high-quality car parts for NISSAN MARCH III (K12) 1.4 16V 65kW Petrol 2003-2010 at reasonable prices. We deliver all over the world. Quality guarantee. Get advice from professionals on ALVADI.EE
