Hope someone out there might be able to shed some light on this weird problem.
It all started after a 45 mile run over a year ago the car all of a sudden started holding back and then no power, upon pulling over the engine would continue to run as there is no pressure on the engine, but the minute you applied the accelerator the car was going no where.
Switch the engine completely off leave for say an hour go back to it and everything is perfect engine runs as sweet as a nut and plenty of power.
It never happened again...
However its done this a few times and now all the time.
Soon as the temp blue light goes out showing up to temp, no power, giving the impression the engine is going to cut out but it doesn't providing you don't put any pressure on the accelerator.
I suspected it could be an Oxygen sensor but trying to find someone round here with a tester to test the upstream or downstream some of the garges I rang don't do this, and one was not available.
So I decided to order two Oxygen sensors and replace them myself I'm certainly by no means new to mechanics.
Firstly when the engine is cold there is tons of power and car runs awesome, the minute it reaches temp it starts to mess about, holding back, no power almost like blockage, however it certainly is not a blockage.
Pull over on side of the road wait until engine cools down say when the temp light is in cold (Blue) off the car drives totally perfect until it reaches operating temp.
Having no tester I decided to go for the downstream sensor as the upstream sensor looked as though it had already been replaced at some stage.
After replacing I road tested it and everything from cold was perfect plenty of power and then soon as it was hot (Blue) temp light off it starts messing around again.
I then before replacing the upstream sensor and when the car was messing about, disconnected the plug to see if there was any difference and it made no difference what so ever the fault was still there, struggling.
Any ideas would be a help in identifying what is actually causing this problem, what ever it is I totally believe is electrical, maybe another sensor someplace (MAP) maybe or temp related Temp sensor which I highly doubt.
I was a complete dummy could have saved myself a lot of work, when I suspected an oxygen sensor I should have disconnected one at a time to see if there was any difference so food for thought if you suspect.
