Hello,
A few days ago my Nissan Micra K11 (from 1999, 1.3 petrol) stopped running. It cranks but it does not start.
The car had some difficulties starting after being parked at an incline. A few days later it stopped starting at all. Since the engine cranks, I started looking at the fuel: replaced fuel filter, replaced fuel pump (thought it had gone bad, the old one made sounds when I shook it, so it wasn't in great condition either). I mention I saw some metal filings inside the small reservoir for the fuel pump. I thought they came from the failing pump.
Nevertheless, the car does not start with the new pump. It seems that was not the problem. After looking at some youtube video, which showed that shorting an injector to the battery might solve the problem I checked the continuity of the wires.
I have continuity from the battery to the relay. When testing from the relay to the rightmost injector I get a resistance oscillating between 400 and 1200 ohms. Testing a connection nearby (MAF sensor?) shows 400 ohms. Is it normal to have such high resistances or should the meter just show continuity?
What would you suggest I try next? Thank you in advance for all your advice.
