Micra k11 1.4 difficulty starting
Hi I have a 2001 micra active 1.4 with 50k miles from New which has difficulty starting. New plugs fitted healthy spark good fuel pressure, engine turns well but will not fire. It seems that the fuel is not being fed to the injectors. Does anybody have any ideas what to look for next. There are no fault codes coming up. Any help or advice would be appreciated thankyou.
Hi, we had a similar sounding problem with a 2001 1.0 Micra auto. Following suggestions from the forum, I swapped the blue relay (which is housed second from the front in the black oblong box beside the battery) for a secondhand one (part number 252309F920). This resolved the starting issue.
