Hey Andy, you are a wizard mate. I wondered if you might know what my problem is on my W reg K11, 1 litre auto. The car won't roll easily in neutral, as if the brakes are binding (all brakes work perfectly - not binding), and after a few miles, maybe 8 or 10, the car stays in 1st gear and won't shift up. Shifts ok again after it has cooled down. The car has been off the road in a garage for around 13 years. Gearbox works fine when driving until it heats up. Gear selector is a bit notchy and slightly difficult to move from P through to D and back again. Transmission fluid is clean and clear, and up to the level. I am a competent technician with 40+ years of the trade and not afraid to tackle most jobs, but I'm not familiar with these transmissions. Any pointers would be greatly appreciated. Many thanks in advance for taking the time to read this. AlanHi Abaaba just came across your thread!
If your engine is a 2000 onwards NCVT engine then you have a filter and a conventional torque converter (as Frank said) so is slightly different to my 1997 NCVT but both engines have a electromagnetic powder clutch, it is important to check the wear on the electromagnetic brushes and this is a fairly easy task. The electromagnetic brush holder is located on the front of the transmission case but for ease of access you should remove the battery and battery tray and also unclip the fuse box holders attached to the battery tray. Remember to disconnect the battery before starting!
Location of electromagnetic brush holder:
The battery and tray removed the brush holder is to the left of the dip stick holder/tube (can't see in this pic)!
Then unplug the brush holder electrical connector and undo the to retaining bolts carefully (this is the new brush holder in place)!
Old brush holder removed exposing the electromagnetic armature on which the brushes make contact!
The brand new genuine Nissan Electromagnetic Brush Holder and Brushes (£200), you could try and just solder in new brushes or if available use a cheaper clone version but this is such a vital component for the continuous optimum performance of the NCVT IMHO I did and would always buy genuine Nissan parts for reliability and piece of mind! The part number I was told by a Nissan dealer is the same for pre and post 2000 NCVT transmissions but check!
The left is the old worn brush holder and the new one on the right the old one does not look to worn but it was. There is a worn line indicator on the brushes which had been worn away on the old ones!
New brush holder in place and bolts correctly torqued!
Everything back in place job done!
On the test drive after the renewal of the electromagnetic brush holder and brushes there was a marked improvement and increase in pick-up and smoothness of transmission performance!
For more information on this task it is best to get hold of a Nissan Micra 1993 to 2002 (K to 52 registration) Haynes Service and Repair Manual Chapter 7 Part B Automatic Transmission Section 3.
For your reference your transmission designation is: RE0F21A
If you need anymore info please feel free to message me!
Andy![]()
Hi AndyHi Abaaba just came across your thread!
Andy![]()
You mentioned your nissan is a CVT transimmission? If there the gear doesnt engage after all you ve like top up the fluid or replace the fluid, you may check also the fuse located near the battery there is a cvt fuse there inside, then other option is might be your transmission control module TCM is faulty this one located underneath dashboard try to change this too...It is me again
Engine code CGA3DE Title should say 1.4 but I cant edit it.
The car is in really good condition and only done 45k but has no drive, when gear selector is moved to R, D or L you can hear engine RPM change. I press on the gas pedal and the spedo is not moving at all. I will have to get the driveshafts out and see if they are the problems but waiting when the weather is a bit better
Is there any more checks I can do before condemning the gearbox and hunting a second hand one from scrapyards?
checks done so far.
front wheels move freely so no frozen brake calipers
Gear oil was a bit low and dirty so I have changed it but still no drive
I get someone to sit in the car with reverse selected & their foot on the brake, engine ticking over, looked at the driveshafts from under the front of the car none of them was turning.
Hi i have nissan micre 1998 automatic gear box When i start the car and it become so hard to put d or p and When i Trun off the car and gear working well moving to d and pHi Abaaba just came across your thread!
Andy![]()
