So ive finally decided to go with the CG10/13 swap instead of GA16DE, since it will be alot easier, and there are many benefits with the CG engine, alot lighter so cornering won't be ruined, not that it matters anyway since the car is going to be stanced, and not a track car.
So far ive come up with that i will only need one new engine mount to make it fit, and that i can use the 5-speed gearbox from the MA10S, but what driveshafts and hubs etc should i use?
The ECU is another problem, ive read that the keys have a chip, the donor car is a -94 with CG10, do they have that or is that only later yearmodels?
What kind of triggerwheel is used in the CG engines? i might use Megasquirt ECU later, if the stock isnt good enough.
Im also wondering if someones got extensive service manuals (preferably nissans own) for the CG engines.
