Please help me with the tranny on my 94 k-11 1.0 It has a n-cvt that uses a foot pedal clutch. Sort of like a motorcycle used only to stop and go. The problem is that I cannot find any info on this particular transmission. It has a hydraulic clutch and I can see that the fluid leaks. How can I adjust this clutch because if feels like its slipping sometimes. Also its weird because I can start it in park but it makes a grinding sound like its partially engaged and then it diew out. If i stary it in neutral then its fine. I checked the gear selector cable and adjusted it but it made it to where I could not start the car ...just a clicking noise...so I put it back where it was...seems like it was the factory setting. please help me. Thanks soooo much!
