Micra DIG-S rough idle / stalling
SplanK
Site Supporter
Just to start a thread on this.
Our DIG-S Micra has occasionally stalled on me for no apparent reason in the past with the clutch fully disengaged such as waiting at junctions. It was always random, out of the blue and would me many months between stalls. I just put it down to bad luck/bad timing or something I did.
This morning there was 2 incidents. 1 at a junction where the idle went very rough and it was trying its best to avoid stalling. I went to fill up then drove home, 2nd time I was waiting at a set of lights, was idling happily for about 30 seconds then the rough idle came back then stalled.
It restarted and drive home fine. I could not get it to stall again although stamping on the break peddle does cause the idle to drop and I can hear the exhaust seemingly missing a beat. From the engine, I can here a 'pop pop pop....' type noise, its not loud but seems to correspond with the exhaust seemingly sounding odder than it was.
Not done any further diag work, but will check at lunch time and maybe get a diag reader on it to see what I can see!
OP
OP
S
SplanK
Site Supporter
Just a quick update on this. The frequency of the stalling appeared to increase, including it happening to the wife (previously it only happened to me)
I mentioned the stalling issue to my mechanic when I took the car in for some suspension work. His advise was initially to check and clean the throttle body butterfly valve - its an easy enough task and inexpensive if I DIY.
So can of carb/throttle clean and a toothbrush I got to work. On initial glance the valve looked ok, however once I started cleaning a lot of grot came away. There is quite a bit of oil misting throughout the intake pipes - something that I wont be able to clean. The pipework isnt all that easy to remove but got there in the end.
The car was initially idling high, but wasn't sure if it was burning off excess cleaner in the intake manifold or in the process of doing a re-learn itself as it did come down.
I also used NDSiii android app to complete 'idle air volume learn'.
So far so good. The low idle/rough idle seems to have cleared up and the car has not stalled on us.
OP
OP
S
SplanK
Site Supporter
Well its been almost a couple of months and many miles since I did this work and it still continues to be good and stalling or 'attempting to stall' has not returned.
OP
OP
S
SplanK
Site Supporter
Well, the idle stumble/stalling is back (well, has been for several months).
More often than not, the engine will stumble at idle and revs will drop quite low before it catches and regains its composure, but every now and then it won't catch it and it will simply stall out.
Unable to re-create either symptom on demand and no engine light. I do note the engine has a slight oil loss issue, but not significant (about half a liter every 4-5000 miles), nor have I worked out where the oil is going - there is never any spots on the ground, but when I last pulled the air intake there was a good coating of oil which is making me think oil is getting into the intake via the PCV system. There is no apparent blue smoke but I'm assuming at this point that the consumption is not significant enough to be visible.
Did my original cleaning do anything? I am doubting myself now and that I could have had a brief moment where all was ok. Maybe I need to pull it again and check over the condition. If there is an escape of oil through the PCV system and it consumes oil via the intake then the throttle body will gunk up quite quickly.
I did briefly consider is this an issue with one of the cam timing solenoids. On the note owners club, these solenoids seem to be a common thing to replace but I would assume the issue would exist throughout the rev range and bring up an engine light.
The procrastination on this continues!
As someone who very recently experienced an almost panicky situation because of a failed injector coil on my K13, reading your car problem is making me anxious!
May be try decarbonizing the fuel injectors and the combustion chambers to see if it helps?
Some time last year I used Liqui Moly injector cleaner petrol additive on the K13 more than once and it smoothed out the drive for several days. I read that it clears the fuel lines too.
The effect was more pronounced on my Ford Figo 1.5 Tdci after using the Liqui Moly Diesel additive and going on a long drive; reduced turbo lag and better throttle response!
