I'm looking for a mechanical speedo drive (the part bolted into the box that the cable then attaches to) to convert my gear box from digital to mechanical speedo.
Its a different size!
You cannot remove the digital speedo drive and fit a mechanical one with a speedo cable because the digital gearboxes speedo drive hole is about half an inch bigger.
But the actual drive gear will be a different diameter, therefore a different ratio. So even if you make a sleeve to mesh with the gear in the gearbox thew speedo is going to be out.
Would be easier to swap the gearbox with the earlier type.
Sorted now, bought a mechanical drive and it was the same size with same size cog and same number of teeth. Have been told there are 2 sizes and the larger size is what's needed
