Antony
arrrg.
right then as someof you will know iuve been after a brake master cylinder for my car to make it pass its mot, so i pinched one from the scrappy......
right that was the easy bit, fitted it on....... no problems...... filled it up......easy
come to bleed it....:laugh: no chance.
i got a gunsons one man brake bleading kit, drilled a hole in the top cap to accept the pressure pipe......fitted it to the master cylinder......and it squirts brake fluid all over my hands... from under the cap...
so i tried about 5 different rubber seals........ nothing.... still leaks..
what can i do? cos now i cant bleed my brakes, ad ive only got 1 week till the jap meet.!!!!!!:wow: :wow: :wow: :wow: :wow:
