mass airflow sensor cleaning
Its a bit pricey, normal carb cleaner does the same!
Best thing (in my opinion) for cleaning out carbs, throttle bodies etc. is brake fluid.
Its solvent enough to shift dirt/glazing. Mild enough not to cause damage. Doesn't cause seals to swell up and you can rinse it away with water. Oh, and its cheap!
I'd like someone makes a guide on mas and tb cleaning, I don't want to mess those sensitiv parts
