I would think it would be that simple, but I want to know for sure. Does some kind of resistor have to be installed???
Can anyone who has installed these tail lights post here with help??
if you were a full member you would see their is a guide in the guides section its the same convertion that you have to do if you are fitting march bulb holders to a uk micra. the wiring needs to be swapped round. but no resistors are needed as the LEDs are 12 volts and the indicators are still bulbs even in the LED lights, so no fast flashing problems.
just don't go getting a set and plugging it straight in. you could blow the set.
