Does anybody know if the Main bearings differ between the Cg13de & Cga3de.
I ask, as I've had my cga3 crank polished and balanced, but when fitting new cg13 standard bearing the crank locks up. However these bearing fit a standard Cg13de engine and spin freely and plasitgauge as they should.
The bearing look slightly different compared to the old cga3 ones.
As if they are line bored to a different size. Both the crank journals are the same between the 2 different cranks.
