using morris xfs 80w/140 lsd oil
this lsd matt sent me was a 2-way 45/45 ramp config
during bed-in, the lsd clutch engagement is pretty sharp and when doin 3 point turns its really noisy n stuttering like an impact drill. must advise that you locktight the driveshaft nut cos they will rattle loose and wreck the wheel bearing.
during bed-in when turning, i was initially surprised at the sudden change in stability as the ramps shift direction if the torque load is gradually altered.
entering a corner mid-power the lsd engages and steering turns in at a certain rate. if i ease off till there's zero load going through the diff, the lsd suddenly snaps to open-diff and the front suddenly wants to turn in more given the same amount of steering angle.
so going through corners you have to maintain a constant load.
but now after few thousand miles its all bedded in, static preload is reduced and the engagement is much smoother n gradual n quiet so the mid-corner sudden snap disengagement has lessened
