im looking for a set of k11 35mm lowering springs please
FK Automotive
I have a set of whiteline springs with a coil cut off lowers car approx 50mm
Bargain!Yeah they would and £40 delivered
Spacers can help. But they're quite expensive somwetimes.after i have lowered it the wheels are gonna be quite far into the arches is there a way of spacing out the wheels to align up nice with the outside edge of the arches??
You may need extended studs too, depending on what size spacers you want to useafter i have lowered it the wheels are gonna be quite far into the arches is there a way of spacing out the wheels to align up nice with the outside edge of the arches??
ok ,sounds good. ill take them. is paymnt next saturday ok?? iv got insurance and stuff to payout this week
whats the difference between your whitline cut springs and me cutting my stock springs??
Ideally to correct the axle shift when loweringso i would need to change that red bar for an adjustable one??
you don't have to change it, i drove years without changing it. the only thing is that the car end shifts to the left a bit.
No, but if he wishes to space his wheels out he'll need one so they sit flush.you don't have to change it, i drove years without changing it. the only thing is that the car end shifts to the left a bit.
About £70-80 from Noddie on herebut thats not a good thing really, is it? i might just not bother, it dont seem worth spending out nearly half of what the car is worth just to have it 5cm lower.
Highly recommendedAbout £70-80 from Noddie on here![]()
Highly recommended![]()
fixedyou don't have to change it, i drove years without changing it. the only thing is that the car end shifts to the RIGHT a bit.
left, right, up, down it shifts in all directionsfixed
Just so nobody looks at the wrong side and thinks 'Yeah, there miles of space, I don't need a panhard'. There have been a few on here recently that mean you gotta be that specific unfortunately. Mentioning no names...left, right, up, down it shifts in all directions![]()
nice and cheap thats what i like, thanks for that fella
Yeah course![]()
