I've been reading the recent threads about lowering with interest.
I originally intended to do things in stages, I was going to fit Eibach Pro Kit springs for a short time on the standard shocks using the same strut top mounts and not even changing the rear spring isolator bushes, literally I was hoping to just fit the springs, see how it performed and proceed from there.
Depending what you advice you read some folk say standard shocks are good as long as the drop isn't drastic, others say it's a heinous crime to do that.
Upon inspection I discovered the top nuts of my existing shocks were rusted and most likely wouldn't come off without some destructive improvisation so that put an end to my wanting to do things in stages.
So now I need to buy two front shocks (and the back pair and isolator bushes) and the new strut top mount kits, there's no point faffing around buying some temporary replacements so I am buying a set of four Bilstein B8's, the other advantage is that I can build the suspension legs easier on the bench instead of having to dismantle and use the old shocks which will no longer be serviceable anyway because of the rusty top nuts.
If you add up the cost of buying the best quality components, the cost of lowering a K12 isn't just the cost of some springs, to do a thorough complete job with the best parts you also have to buy the front top strut mount kits, two sets of rear spring isolator bushes, add those to the cost of the springs and new shocks then you are easily having to spend somewhere in the region of £500-£600.
Moral of my story is plan to spend more than you think if you want a proper job.
