If you manage to run them for a quite a while and tested both circulate heating settings and the 'fresh' air setting and still no decent heating then there must be a problem somewhere even gunk in the pipe can cause a slight problem. :down:Mine isn't heating fully either. I think its the weather as there is 6 cars in the household and none of them are completely heating up.
your stat is stuck open, even in minus temp it will get upto normal engine temp, mine was broken but i changed it last week, not the engine gets upto normal temperature fairly quickly but the heater is still pants, i miss my k10 heater
remember to turn the heater dial to cold during cold starts to speed up the engine heatup period. only once the engines up to temp do you then turn up the heater.
Get som antifreeze. (Y)my heater was (surprisingly) working fine today, tho my tophose was full of slushpuppy this morning (it must have been about -10 last night)
