M
Mulbers
Hi,
I'v been having problems with my K10 1.0, 4 speed. I was driving down the motorway a few week’s ago about 60 and started to go up a slight hill. The car lost a lot of power and then jolted violently with a sound of air was escaping under pressure.
Carried on driving (this has happened before but kept going fine, so didn’t think too much of it.) it was only until I had stop that the car seemed to be running rough.
Took one lead off at a time and found No. 2 wasn’t firing. Carried out a compression test, all running at 195psi except No.2 which was at 30psi.
Im sure it is not the rings, and the valves (from the rocker head cover view) seem fine.
Has anyone had this problem or similar?
Help would be greatly appreciated. Cheers
