Hi all,
Looking for a bit of advice, I've got a 2002 K11 1.0 with 65k miles on the clock, ran perfectly until September time when it seemed to lose power, it would struggle to get up to 50-55mph and going up steep hills is 20mph flat out in second gear. It sat SORN till last week when I got it MOT'd and have been trying to sort it out since.
I've given it a new air filter, oil+filter, new fuel filter, new spark plugs + ignition coils. Didn't expect it to change much but they needed doing. There's no engine light, no codes.
Having a read around it seemed like it could be the MAF sensor so I unplugged it and noticed no difference whatsoever, decided to buy a cheap one off of ebay for £25 and put it in today, the car was struggling to idle and stalling every time you put the clutch down. When I tried accelerating it would yoyo all over the place and I had to come off the pedal and put my foot back on to get it to accelerate again.
Decided that didn't seem right, unplugged the battery for 20 mins and then let it idle for a few minutes but no change (no idea if that would help but thought I'd try) so I've switched back to the old MAF for now (not that it seems to do anything).
I took the rocker cover off today as well while I was at it to check the timing chain, that seems fine no play in it at all, was going to try loosening the cat and see if that helped but got a round bolt I can't get off at the moment on the heat shield so couldn't try that.
Any advice appreciated, I'm wondering if I should get a brand new MAF from somewhere more reputable or try a second hand throttle body or something?
Thanks!
Thanks!
