I've been using a JUN ultralight 3.4kg flywheel with a really heavy duty 200mm Helix organic clutch on a daily basis since 2010 and imho you get used to it with practice, the same as adapting to any vehicle.
it only stalls if you don't give enough revs or don't pay attention but you soon learn the fine balance between clutch-slip vs throttle vs rpm. the rapid engine response is gr8 for accelerating, upshifts, downshifts with heel&toe. idles like normal too.
