CMF_manofaus
» CMF MemberI have read that you kink a line when you need to stop your micra engines from running lean when doing the cold air intake and 4-2-1 headers. Could you do the same if you got an adjustable regulator?
Are there different series of engines for the micra (after info in 1.3l) and which one would be the pick for an engine that was going to get supercharged/turboed at a later date.
Note this engine is for a 1964 retro fit into a MINI!!
thanks
thanks
