Turtle,
Your pictures and info are good clues! Thanks for posting them
I am with Fordy on this one....give em a clean up or get new and check them again after a week or two of use.
I realise that the pics are dark, but it seems to me that there are no plugs with oil on the parts that protrude into the combustion chamber.
Your No 2 & 3 may be darker, but not excessively darker than 1 & 4. My engine is perfectly healthy from an oil and fuel efficiency point of view and my 2 & 3 plugs are darker than my 1 & 4. I wouldn’t worry about that too much.
The blackness on your plug tips looks more like 'gum' to me. If you’ve got this much gum on 7 month plugs, then you must be the world record gummiest cylinders holder....lol
Also, your No 3 plug is shiny & oily, but not on the centre electrode insulator.....??hmmmm
I panicked on a routine plug check last year. My No 3 plug was well oiled up, but when I looked closer, the bits that protrude into the combustion chamber were dry and healthy! As it turns out....No 3 plug is directly below the oil filler cap! In my opinion, this oil is more likely to have come from a spill-over or miss when you have been topping up. If this is the case, the oil will sit in the plug well forever as there’s no drain holes in the plug wells .....If you still have the plugs out...some well illuminated photos would be ACE.
Interesting though, after your oil clean, the exhaust smoke reduced...this does suggest burning. If you are burning it, then it can be piston rings, valve guide seals or cylinder head gasket.
There does seem to be a hell of a lot of old oil on the underside. I would clean this as best you can now, and see if you can find where this is coming from over the next few days.
Thinking from a different angle:
Are there any signs if 'rust' in the plug earth electrode (the hooked bit)?
When you drained the old oil, was it jet black or did it have any light brown stuff/ bits floating around? Or any pools of water in the oil? Is your coolant level been / is OK?
Is your running temperature normal?
Hell!...sorry for all that its almost a page full!
