laptop help please
Im thinking of buying this
http://cgi.ebay.co.uk/ws/eBayISAPI....80014544738&rd=1&sspagename=STRK:MEWA:IT&rd=1
Now it may look silly since it has all those missing peices but i have the exact same one already but with a cracked screen, well my sister has it and as said if i can get it fixed its mine. do you think it would be easier to remove the screen and replace or remove the hard drive from the one i have and place into that one? if i won it.
also while im here the laptop which we have now makes a funny noise when i turn it on, its like something has hit the fan inside, it makes a grinding noise like a goosed bearing type sound or as if some is catching somewhere.theres a vent roughly where the noise is coming from.
Changing the HDD is alot easier that changing the Screen (Hard Drive on Mine is 1 screw then it slides out), you could change the screen, but that would just take a little more patience and work, but very possible.
AS for the grinding noise, could be something stuck on the fan or the laptop has been dropped/thumped
seeing as were talkin bout laptops, anyone know where i can get a decent laptop for cheap, im gonna need one for uni...........
Ebay
Whats the spec on it, cos i have no idea whats good or not. it needs to be able to hold cad programs ( i think) and probably a lot of porn?
hughes_16v said:
I did, it said swearing is not tolerated and fudging was edited, fudging wasnt swearing.
There was a racial reference in your post which was removed. It's just a coincidence your language was also edited out in the same post.
This is off topic, back to discussion please!
What CAD packages are you looking at? If you're looking at 3D cad then you want a MINIMUM of 1GB ram with a 2000+ Mhz processor.
My work computer is an:
athlon 3000+
1GB RAM
130 GB HDD
and it struggles sometimes using Solidworks and AutoCAD 3d modelling!
where i work they use Licom (roughly £10,000 to buy) xeon processors are used...i would recommend a P4 because of high cache levels and fast FSB
