Hello
my car approaches the 100 000 KMs, lambda sensor has never been changed, do you think it worth the 100euros asked for ?
Will it really bring better fuel economy?
Seb
you tap the + lead into the middle wire on the lambda seb, and earth the other lead
the voltage usually goes up to nearly 1v when you rev it, and nearly zero when you lift, and should swing around .4 to.6v if you hold the revs at 3k rpm :grinning:
