Key code for radio/cd player
Hello
I have a 2005 micra and had to change the battery recently - and now the radio/cd player is asking for a code. I wasnt given a handbook when I bought the car and dont have a code. It is a factory fitted radio/cd player and not sure how to get it out to look for a model/serial number. The only number I have found is 55610190794 but not sure if this is the serial number.
Hope someone can help please
Estelle
if it begins BP then yes it is, But you have 1 digit short there should be 12. but with the digits you have posted it generates the code: 2672 and 0672
Hello
I tried both of those codes but neither worked....thanks anyway. Now it just says 'wait 1H' . Think I might just have to take it to a dealer - but not impressed as they want £25!
Regards
Estelle
Rabbitmoon - remove your headunit (see my sig for link) and get us the serial number - won't cost you a penny :).
Hello 6.5x55, thanks for the link to your site, that looks quite straight forward - will give it a go when have some time off and let you know
Rabbitmoon
Audio/Radio code
Please help me with audio/radio code:
Clarion
Serial №: PP3001MB 0051472
Thank you in advance!
Evgeniy.
Hello
I have finally managed to get to the radio on my Nissan Micra - thanks for your advice. I now have the details as follows:
Blaupunkt WERKE GMBH
BP3349 5 8128823
Nissan MM CD-K
7 643 349 318 and another number alongside this 022458
Hope you are able to assist with the code
Much apprciated
Estelle
Not at home at the moment Estelle but I'll sort it for you later if you still need the code :).
That would be great, thanks, however my radio is still saying 'WAIT 1H'. I'm assuming I have to leave the engine running with the radio on for at least an hour for this to clear???
Estelle
Hello Guy
Just wondered if you had a chance to look for the code for my radio/cd player yet
BP3349 5 8128823
Nissan MM CD-K
Much appreciated
Estelle
No need to leave the engine running :eek:. try 9600 or 1200, how's that for service :grinning:.
Hello Guy
Thanks for the codes, thats brilliant. I just need to wait now for 'WAIT 1H' to go before I can enter the code.
Will let you know how I get on
Much appreciated :grinning:
Hello Guy
'WAIT 1H' finally disappeared today - after giving the car quite a long run. Tried code 9600 and it worked first time - I'm so happy! Thankyou once again.
Info for anyone waiting for 'WAIT 1H' to go - we just did quite a long journey with the radio switched on, and it just returned to '0000' (asking for the code) which Guy had kindly found for use. Just entered it and it worked 1st time - not sure what would have happened had we turned the radio off before entering the code - it possibly may have started counting again and we would have probably had to wait again. We didnt take any chances and entered the code before turning off and all is fine now.
Much appreciated, Guy :laugh::laugh::laugh:
Hello Guy
hello mam
how long did u wait for the WAIT 1H sign to go as i have been waiting for the last 4 days and i've tried everything i could but no luck
I need to find out the code for my nissan micra 05. The serial number is BP334958134119. Also once I've got the code, how do I ener it?
Hi i am from macedonia,end i am new on this forum.Please help me about my radio code.The SN BP538458813615.Only you can make this.
Thanks ;)
Thanks ;)
Need part number as well, not just serial number ;)
I think to put the code in you press numbers 1 to 4 the number of times of the number needed
eg: code is 1234
You'd press 1 once, 2 twice, 3 thrice and 4 four times ^_^
Then enter/volume or Ta depending on your system
eg: code is 1234
So my code is 1234 ?
Thanks ;)
Hi, I just bought my Nissan Micra (2005) by a Dealer and they provided me the car without user guide and with the radio asking for the code ! I managed to remove the radio and I got both the model ( BP 334958130131 ) and the serial (7643349318). Is there somebody able to provide me the code ?
Thanks !
Francesco
Thanks !
Francesco
Hi Francesco,
I get 1191 ;)
Hi mate please can you help my battery went and my radio needs a code I haven't got... I followed your guide and got the radio serial no. Which is BP538471195579 7645384318
Thanks in advance
I get 0619 ;)
Hello Jen 319,
I'm new to the site today and you seem to be the radio code guru "par excellence" so I really would be grateful if you could please sort one out for me. I've got BP536258411290 ( last one could be a 6 ) and 7654362318. Lastly there is an E1 in a box with 024173 alongside it. Please can you help?
Hello Jen 319,
Awww, shucks you :p
If the BP number definitely ends in 0 then try 0393
If it ends in 6 then try 0867
With the numbers you've given, my calculator isn't giving me a second code, could be my app playing up <_<
Awww, shucks you :p
You are a legend Thankyou very much, correct first time.
Please please can you help. I changed my battery and don't have a code. Just had someone pull it out to see if a code was on there but it wasn't. I did find the serial numbers though.i have
BP334958147730
And
7643349318
Really hope you can help with a code. Big thanks
Hi there,
Daughter's just bought her first car...1996 micra, but we don't have the radio code.
The serial number is BP6340T3155179
parts number 7646340318
If anyone knows the code that would be brilliant.
