K13 steel wheels, what is the EU spec + Offset
Right so this is my first post here, Hello!! I'm an Alfa head myself, but the girlfriend has a Micra so I get tasked with the maintenance, they are pretty neat and easy to work on, I am impressed.
Anyway I need a new steel wheel for the Micra its a 2011 model 1.2. (French model) The tyres are : 165/70 R14 In the service manual the rim specs are : 14×5-1/2J 45 - The offset is 45.
On the USA micra forum they say the offset should be 50... see here : http://micra-forum.com/showthread.p...-pattern-hub-bore-offset-same-as-Versa-Note-)
So my question to you guys is what is the correct spec - the wheel finder on the website (oponeo) I use specify both... E45 and E50 so any ideas ?
Looking on the rim it does not specify the offset but does specify every other detail....
Thanks in advance BT!
