Hi Guys,
Does anyone have the K12 service manual, i could not locate it from the usual full stop links it seems to be down.
Got a call yesterday when i was out on the bike that she was not able to start the car. Jump start was the first thin that came to mind so spun home (wasted day
) and tried to turn it over starter was turning over. Checked the batter 13V + on it so that was fine. The car is driven during the week so regular. There was never a management light on it but it does appear at ignition so it works.
Checked was it sparking all 4 were fine, The were wet too from numurous attempts so fuel is pumping, removed the plugs and dried them all off. replaced again. Its turning over but no more life than that.
Plugged in the OBD and getting codes.
P1122
P0223
P0123
P0113
P0107
All seem to be Throttle Body Sensor related. At this stage im perplexed. Anyone have a copy of the ESM also any thoughts on what to do next.
Ive cleared the codes down, and just removed the battery to reset everything. Going to give the Cam Sensor a clean later after work. And need the ESM to locate the Throttle body sensor as not 100% where it is located.
Thoughts?
Suggestions ?
Anything really.
Cheers!
P1122
P0223
P0123
P0113
P0107
Thoughts?
Suggestions ?
Anything really.
Cheers!
