Bp538469484068 please could I get code.
Hi there could anyone tell me the radio code for my wife's micra. cables that go through the rear hatch back had broken and destroyed the battery. Really appreciate anyone's help.K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
Could someone let me know if I'm on the right thread please. I'm relatively new to the site and a bit unsure if I'm doing this correctlyHi there could anyone tell me the radio code for my wife's micra. cables that go through the rear hatch back had broken and destroyed the battery. Really appreciate anyone's help.
Bp5387 6 1120371
Hi I've just replaced my battery but I don't have my code can you please help serial is BP536258433800 many thanksK12 Radio Code Thread
Thank you so much!
Bp334947254455K12 Radio Code Thread
BP536258433800Bp334947254455
Hi,BP536258433800
Thank you I have got tunes again 3849 workedHi,
Code is . . 3849
Hello,Hello,
My car just popped a message for a Radio code, could anyone provide assistance please?
BP538771236667 Model: 7645387318
Cheers,
K.
HiWith all due respect, please WAIT!![]()
You have to bite the bullet and find the BP number by extracting it?Hi
The kindly old gent who sold me the car didn't have the code but showed me how to bypass it. It is a bit of a carry on so I would like to use a code.
I can enter 4 digits code without waiting an hour but is the code specific to that radio or will others work/ When I enter a code from these pages the volume button doesn't do anything. Will I have to bite the bullet and find the BP number by extracting it? Or wait an hour and then try?
Hi. The code is different for each serial number. You can find it behind the stereo. Mine was a bit of a nightmare to get to. It was also bolted in from above. Figured out that I had to pop off the top of the dashboard to get it out. It will pop off like a door card. Hope this helpsHi
Thanks for the reply. I will just keep doing the "three finger" technique as I really don't wish to disturb the dash.Hi. The code is different for each serial number. You can find it behind the stereo. Mine was a bit of a nightmare to get to. It was also bolted in from above. Figured out that I had to pop off the top of the dashboard to get it out. It will pop off like a door card. Hope this helps
Thanks for the reply. I meant extracting the Radio from the dash and reading the BP number. I will continue with the "three finger technique" to bypass the code as I have no wish to disturb the dash. Regards.You have to bite the bullet and find the BP number by extracting it?![]()
I know what you mean. It's not really the dash as such. It's the flat cover which goes on top of the dashboard. It is designed to lift up.Thanks for the reply. I will just keep doing the "three finger" technique as I really don't wish to disturb the dash.
Ok, thanks. Might have a look at it again.I know what you mean. It's not really the dash as such. It's the flat cover which goes on top of the dashboard. It is designed to lift up.
Don't be a wimp! Be brave!Thanks for the reply. I meant extracting the Radio from the dash and reading the BP number. I will continue with the "three finger technique" to bypass the code as I have no wish to disturb the dash. Regards.
Moi Virkku!Hello,
can anyone help me to get code to the radio, BP738387799691
thanks in advance
Hei Mika,Moi Virkku!
Are you Finn?![]()
K12 Radio Code ThreadWould you be able to give me the radio code for a Nissan Micra 2008, serial number for radio is PP3000MB0004657
Hello,Hello,
thanks in advance
Hi,Hi can anyone supply a code for BP234720860483. Thanks
Wow, that was quick, thanks a millionHi,
Code is . . 7142
Hello,Hello, Could you please let me know the code for my stereo?
it's a Nissan MMR#2 CD-G BLAUPUNKT 7647383318
BP7383 A 9407356
Cheers in advance.
Hi,Hi there, could you please help with a code for stereo serial no. BP5384 6 9477232.
Neil
Worked a treat, many many thanks-much appreciated ??Hi,
Code is . . 2273
CheersHello,
Code is . . 5570
it's a Nissan MM CD-K BLAUPUNKT-WERKE GMBH 7643349318
BP334958148756
THANKS IN ADVANCE
Hi,Hi. Could I have a code for BP538761136618 if possible. Thanks
Many thanksHi,
Code is . . 7023
Many thanks
Thanks allot
Apologies for the delay in seeing this.....the number that you need is 1340...Hi. Would you please provide the radio code for my son's K12 2007 micra?
The serial number is:
BP538471207848
It is an original Blaupunkt radio.
Many thanks
Will
Thank you. I will let him know.Apologies for the delay in seeing this.....the number that you need is 1340...
