Hi, try 6254 or 0254....
thank you very much! 6254 worked. Really appreciate you taking the time to do that.
Simon
Hi can anyone give me the code for my car radio serial number is BP536258038722K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
And never thought to feed 12V from other power source to battery cables, during battery swap, to avoid this common problem here...?!Hey guys, changed the wifes battery and now the radio wants the code:/
Serial: BP538471211038
Part no: 7645384318
I would, BUT the battery was completly dead before i changed it. Happened overnight, it went from +5C to -20C wife came to the car and not even ignition would light up. ?And never thought to feed 12V from other power source to battery cables, during battery swap, to avoid this common problem here...?!![]()
Try 2755!And never thought to feed 12V from other power source to battery cables, during battery swap, to avoid this common problem here...?!![]()
Try 1901Hey guys, changed the wifes battery and now the radio wants the code:/
Part no: 7645384318
Hi, try 4465Hi can anyone give me the code for my car radio serial number is BP536258038722
Test 0823Hi! My wife's car. She forgot to close the door. The battery went off... I will be happy if someone could help me with the code.
The serial number is LP8635123674 with 3 at the end. Thank you in advance!
Thank you for your quick reply! Sorry. Didn't work. But I checked other serial numbers. Maybe they can be useful. BP5387 6 1129471. 7 645 387 318.Test 0823
Hi, check in the label of radio, and see the SN and PartThank you for your quick reply! Sorry. Didn't work. But I checked other serial numbers. Maybe they can be useful. BP5387 6 1129471. 7 645 387 318.
Thank you again!!
Add picture...Hi, check in the label of radio, and see the SN and Part
Try 1901Thank you for your quick reply! Sorry. Didn't work. But I checked other serial numbers. Maybe they can be useful. BP5387 6 1129471. 7 645 387 318.
Thank you again!!
Try 1901
It worked! Amazing! Thank you very much!Try 1901
Try 1901
Hi, try 5507 or 1507.......Hi,
Can I get some help as well with this radio code?
BP538461727171
7645384318
Thanks a mill.
Just tried and it worked, thank youduplicate reply.......
Hi, try 2492 or 0492........Hi! The classic battery change and in need of code, if someone can help would be very much appreciated!
Serial Nr: BP234732029853 & 7642347318
Cheers!
It worked! Thank you! Now I have a happy wife thus a happy life. ?Hi, try 2492 or 0492........
Здравейте, опитайте това 2024 или 0024............Google translate е вашият приятел ....;0)здравей Наскоро съм собственик на Nissan Micra и харесвам много други имат проблем с радиото Ще се радвам, ако някой помогне с кода ....... BP234732052231 ....... 7642347318
Hi, try 2936 or 0936......Hi everyone I have the same problem.
My radio need pin code
Here are the numbers
BP334947241075
7643349318
Thank you
Thanks a lot! It was 2936!Hi, try 2936 or 0936......
Hi, just one possible for this, 0192........
Hi there,K12 Radio Code Thread
Hi, try 9337 or 1337...........Hi there,
I’m after the code for our Nissan Micra radio (post battery change)..
SN: BP2347 32019999
Any help would be massively appreciated!
Many thanks in advance!
David
Hi, only one possible for this as well, 1212.........Hello, can anyone help with a radio code please,
BP5384 71207822
thank you
All working now, thank you very much.Hi, only one possible for this as well, 1212.........
HelloK12 Radio Code Thread
thanks a lot, it worksЗдравейте, опитайте това 2024 или 0024 ............ Google translate е вашият приятел ....; 0)
Hi could you help me get a code for this please bp538458816708thanks a lot, it works
Hi, try 7532 or 1532.....Hi could you help me get a code for this please bp538458816708
Hi, try 4346 or 0346......Hi,
I need a code for 2005 K12 Sport Plus
BP538752990025
other codes:
MMR IDC-G 66700006288
28 184 BC41A ZH-D912
LP 8 635 123 615 3
LP 8 635 123 522 1
K122102534
7532 worked sir thank you very much, your a legend ?Hi, try 7532 or 1532.....
Super mate,Hi, try 4346 or 0346......
