The 'BP'part of the quote is important as that signifies that the radio was made by 'BlauPunkt', which is the only make that I can decode. something that has been repeated on here numerous times ...........and something a few people seem to miss......Please excuse my ignorance but I didn't know how else to post on the thread so I shared the "BP" quote.... Sorry ?
I don't think that you will as the 'CL' number that you already posted shows that your radio was made by Clarion, not BlauPunkt.........Apologies, I will get the BP number ASAP, thanks for the info.
Rich
That’s what the logbook said, but it did not work, I might need to remove the radio itself to check the serial no. on itHi, try 4197 or 0197.......
Hi, try 2593 or 0593.....Please can I have the code for my nissan Micra k12 ?
BP536358270680
8 635 123 392.0
Thank you in advance!!!
Thank you very much for your reply!!Hi, try 2593 or 0593.....
Hi, try 8996 or 0996.....Could some kind person provide me the code for
BP5387 6 9669877
Many thanks
Joe
Wow that was fast, thanks ! I'll try it when my daughter is here with the car at the weekend...Hi, try 8996 or 0996.....
Hi, try 4401 or 0401........I would be very appreciative if someone could help me with minehope this is the right thread
BP 5387 6 9684120 [126]
7645 387 318
You legend thank you so much!! All working nowHi, try 4401 or 0401........
Hi, try 7664 or 1664....Hello everyone !
I need a code for the radio as well please
Serial Number: BP5362 5 8441928
Part Number: 7 645 362 318
thank you !
Hi, 0719 should remove the desperation and bring a smile to her face (and earn you some brownie pointsHello!
I'm in an urgent need of the code for my mother's Radio code, she's departing for a holiday tomorrow afternoon and she's quite desperate about it ?
I have looked pretty much everywhere on the web but I still can't, for the life of me, find the code or a working generator... if anybody could help, it would be wonderful. Thank you in advance
SN. BP 5384 6 9491641
P.N. 7 645 384 318
Thank you for the swift reply, that's very kind of youHi, 0719 should remove the desperation and bring a smile to her face (and earn you some brownie points).......
Yes the radio has to have power on for the 1 hour period....Thank you for the swift reply, that's very kind of you
I have a question, though... when you put in a wrong code, a 1hr timer starts... does the radio need to stay turned on for the entire time in order for that timer to go away?... I turned it on after 5 hours and it still has that message on the display.
It worked !!! Thank u very much ! : )Hi, try 7664 or 1664....
The code works. I wrote it in my notes so that if this happens again in the future we're safe XDYes the radio has to have power on for the 1 hour period....
Didn't get alerts for this and the next post so only just seen them.....I have to drive my friend's micra 100 miles tonight with no radio, unless someone can give me the code for it please?
Serial number is BP538469489173
Thanks in advance.
Hi is this the same radio that you were enquiring about 3 years ago? Don't think that you posted the 'BP' number then..... Any way correct info supplied this time, so try 9843 or 1843..........Hi wondering if you could help me get my radio code please:
Serial Code: BP 5365 5643 7688
Thanks in Advance
Well if 'BL' is a typo and it really is 'BP' then your code will be either 9566 or 1566.......Sorry I may have posted this in the wrong thread, can you help please my serial number is
BL 5384 7120 6523
It was a typo yes and thanks 9566 worked radio back up and running after 2 years. You're a star.Well if 'BL' is a typo and it really is 'BP' then your code will be either 9566 or 1566.......
Not missed, just not decodable by me....Hello. I think my message got missed. Please help. My battery died and code does not work. Please can you help.
Serial number 3136252
Device number 7612830023
Date 10.04.14
Many thanks in advance.
Hi, try 7534 or 1534......Good Morning John.
Same request as others please, if you can.
I am stuck for a code for BP 5389 6 2406164.
Regards,
Ian.
Hi, try 3639 or 1639....Hello, please could I have the radio code for BP538769683595. 7645387318
many thanks
Hi, try 9712 or 1712......The battery recently went flat on my 2008 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
BP 7 383 8 781 0253
It would be amazing if someone could send me the code for this!
Many thanks
Thank you John, worked first time, fantastic to have my radio back! ??Hi, try 3639 or 1639....
The radio itself is coded...Hi, I have a silly question! My radio works fine but I melted the front of it with solvent by mistake. I bought this part thinking ill just hook it onto the old radio. My question is will this part be coded? Or is it the actual Radio units that are coded?
Thanks, John. I'm new to the forum but I think I read a guide from you a while back on how to modify the controls around the heater dials and behind them. That was a life saver!The radio itself is coded...
