K12 on k10?
1
105
Hi,
Does anyone know whether a set of k12 alloys (14") would fit on a k10?
(sorry if this question has been asked before)
k12 wheels are 4x100 pcd same as k11 and k10. dont know if c/bore is different though?
There are two figures which are important when it comes to wheelsize. offset and PCD. The PCD may be the same (not sure if thats true) 4x100PCD, and offset between 35 and 38!
i would appreciate if you could Clarify this .... will 14 inch alloys on a K12 FIT on a K11...
No - the PCD is different because the cars are french.
Clio wheels for example will fit on a k12.
K11 wheels will not. Just like k10 wheels will not.
Renault Clio wheels fit the K11 shape micra though ...... I stuck a set on my mum's Micra
They're 4x100 with an offset of 35
Arnold said:
There are two figures which are important when it comes to wheels....
3 if you count centre bore :wasntme:
admittedly, the centre bore on the Clio alloys was a little loose (60mm vs. 59mm) but they fit fine
early clios were same as k11 pcd also. i'm not sure what problem you encountered.
