K12 mk3 headlight / headlamp adjuster
Hi all,
does anyone have experience / knowledge of adjusting the K12 mk3 headlight that they'd care to share please?
Mine is a 57 plate '07 K12 mk3, I don't know of the differences in slightly older and newer models but that may be helpful.
I think the end of the adjusting screw has detached from the reflector cone but could do with seeing a diagram of how it should be if anyone can share please?
It has failed the MoT due to the high / low adjusting screw being inoperative.
Cheers,
Ross
If it has the electric aim adjust by the wheel,then the adjuster turns about 45degrees on back of the lamp to release,then you have to push the motor up or down to actually remove it,as its a long pin with a ball head that slots into metal clip attached to the cone.
Sent from my C2105 using Tapatalk
