T TTT Aug 3, 2015 #1 Does anyone have a PDF of the Manual for the K12 - the Haynes or another type? Many thanks Tony
U unjustself Aug 9, 2015 #2 I have the electronic service manual and the haynes book. Anything in particular you need?
OP OP T TTT Aug 9, 2015 #3 Hello Can you please let me know the correct socket needed for changing spark plugs. I've had two different suggestions. If you have the PDF I could do with a copy. Many thanks
azb786 Aug 10, 2015 #4 https://www.dropbox.com/s/mljj611izqtrsby/K12esm.zip?dl=0 Try my Dropbox link. Zip file.. You can either install the programme or find the PDF files under DATA folder. Hope that helps. Last edited: Aug 10, 2015
OP OP T TTT Aug 10, 2015 #5 Hello Thank you so much for sending this. Most helpful! thanks Last edited: Aug 10, 2015
