K12 Fuel Filter / pump probs
Hi all from newby (but very oldie...)
Daughter has an 03 K13 with 1.0 motor n ABS - slowly cut out 4/5 times last 2 days as if running out of fuel. Call RAC to her work said fuel filter most likley blocked nothing they can do.
So - question is - is there a seperate fuel filter underneath or somewhere hidden on the car (not on front bulkhead as some have) ??? or is the fuel pump assembly in tank the only filter (sock) in the system?
Need to sort this asap - blooming dangerous on motorway!
Frank's right, K12s are in-tank. Back seats are easy enough to unbolt if you want to take a look.
Write your reply...
