Welcome everybody ; - )
I have got problem with starting engine in my Micra K12 1,2 65KM (CR12DE engine)
I made short circuit on crankshaft position sensor (POS) joint/plug? because I thought it is the reverse lamp switch.
There was some sound audible near left headlamp, and now:
* when I am switching key to ON position, cooling fan starts (at HI speed).
* Starter is working only 1-2 seconds, then stops -> and engine do not start (cut-off)
* NATS (immobilizer) warning light is continuously lighting.
Everything else works OK
I have Micra Workshop Manual and it looks to be ECM Relay fault, or something else which is in IPDM box near left headlamp.
Do you have any solutions ?
Thanks!
Kind regards ; )
Thanks!
Kind regards ; )
