k12 clutches and flywheels and 4 branch
are all k12 clutches and flywheels the same size and spec?
will a 1.2 clutch fit a 1.6 and so on..same with flywheel
and the does the 1.4 manifold have the same stud pattern as a 1.6?
thanks
this is the clutch size i found on a site caled japanparts... Diameter=180mm, Supline=22mm x 26T
will that fit a 1.6?
1.4 manifold is the same as the 1.2, so neither of these will fit a 1.6, altho if you do some research on the net for pictures of renault clio 4 branch that goes on the back of the engine maybe theres a clio 1.6?
