I'm in need of help.
My 2007 micra has developed a fault, where the fog light is on at all times i.e. ignition and/ switch on or off! This is then draining the battery and so I can't start the car.
I've been told the BCM requires replacing, but at a significant cost.
Does anyone on here know of
1) typical part numbers for the BCM?
2) anywhere that I could pick up a cheap repleacement [new or refurb]
3) have any experience they can offer when it comes to replacing one of these. I'm aware any replacement BCM requires re-coding. Will dealers do this on a customer supplied part?
4) I suspect the problem is a power transistor or relay. Anyone tried replacing one on their BCM?
Any help will be very much appreciated.
