Just brought the car last week, problem Ive been having is a lumpy idle and stalling when pulling up to lights/junctions.
For example if i start the car up in the driveway, the engine runs smoothly when 1st started , it idles at just over 1000 rmp. After about 30 sec the revs drop a little and the idle becomes erratic with the revs fluctuating between 500 - 800 rpm. its almost as if the engines about to stall and it then revs itself up (anti-stall feature ?) to about 800 rpm for a few seconds and the cycle continues. Some times while idling in the driveway the engine will cut out.
The stalling happens when pulling up at junctions or traffic lights, when the clutch is pressed and held in the majority of times the engine will cut out.
Anyone else had experience of this sort of problem?
Model: 1.2 S
Year : June 2005
(BTW - Could any one tell me if 2005 cars suffer from the stretched timing chain issue?)
Model: 1.2 S
Year : June 2005
