Hi folks,
The intermittent speed on my mum's 1993 K11 1.0LX has stopped working.
I suspected it's the wiper relay (the little black box next to the wiper motor). I visited to seperate breakers yesterday and tried relays from broken Micras.
The first one caused the intermittent speed to act really weird. Basically the wipers would start, move about 6 inches, then stop. Then a few seconds later, move another 6 inches and stop...and this goes on and on.
So i gave that relay back.
Visited the second breakers and that relay did exactly the same as the current one already in the car. It basically just causes the wipers to work continuously as if they are on constant speed 1 (position 2 on the stalk).
Soooo... is it possible that both the relays i tried were just faulty as this is probably a common problem on K11's. Or is there probably something else wrong with the wipers?
Is it possible to repair the relay at all? A bit like renewing the dry joints on the K11 MAF - which i did a couple of years back.
All help appreciated.
Cheers.
Cheers.
