N Naz-b23 Jun 5, 2015 #1 Whats a safe psi or boost can or shall i run on my k11 turbo Its on a 1.3 standard block with 2mm copper headgasket
OP OP N Naz-b23 Jun 9, 2015 #4 Right guys a have t25 turbo setup on my micra can i run it around 5 psi without a map
Antony Ex. Club Member Jun 9, 2015 #5 No. 5psi is positive pressure. Your engine works at vacuum. Or -14.7psi 5psi positive is 19.7psi above where it's supposed to be. The car will not be able to compensate for the extra air and will run lean and blow up. Mine runs nistune ecu and sr20 injectors.... But the headgasket still went. And that was only at 8psi. If you can't afford to map it. You can't afford to turbo it either.
OP OP N Naz-b23 Jun 9, 2015 #7 I dont mind getting maped l8er just wondering if its possible without a map thats all no need to get hasty
Antony Ex. Club Member Jun 9, 2015 #9 We're you? I was ragging it tbh lol. But it's still a no.... It will not cope at all with boost without bigger injectors, higher fuel pressure, controlled mixtures and controlled ignition.
OP OP N Naz-b23 Jun 9, 2015 #10 I have all that just dont have the map im just gonna get it mapped saves the hasel
Antony Ex. Club Member Jun 10, 2015 #11 Lol, then you don't have all that. The only way to adjust ignition timing is with a map. It's electronic. But do it. You'll not regret it.
OP OP N Naz-b23 Jun 13, 2015 #12 Ok cheers might just install an av 4 boost controller aswell so i can control the boost level plus psi and other stuff
