K11 Turbo conversion parts & upgrades
After alot of thought i;ve deceided on sticking to a N/A screemer so the following are up for sale, iv tryed to be as honest as possible & prices are not final so make me an offer if you like.. if parts are bought as a package i will go half on postage no problem.. pics will be up over the weeked as well:
Garret T25 Turbo (taken from a 180SX) £65
Will need a rebuild was boosting when taken from low mileage car. No in-out shaft play, does have side to side play
Stainless Turbo exhaust manifold (top mounted) £110
Factory Vacuum operated wastegate £8
Purple 200SX SR20DET fuel injectors (370cc) £45
Factory 180SX exhaust elbow £5
Factory turbo boost pipe & Oil return Pipe £8
Micra Factory Spec exhaust cat-back system £40
K11 Prefacelift Grill £13
Faded but good condition
Is this almost a complete turbo set up then??
Its 90% there Lee, depending what you would want to do really, minimum left id say would be:
Oil Feed pipe for turbo
Exhuast
Boost pipes to throttlebody
Intercooler if you wanted to run one
Lambda fitting to exhuast (welded nut basically)
Exhuast
Does it it have a down pipe from the turbo to the exhaust or does that need to be made?
I cant weld so as long as i have got all the manifolds i can sort every thing els out my self..
It has a 90degree 3inch downpipe but it only reaches halfway down the block or so. it will need some fabrication & pipework to connect it to the rest of the exhaust.
Cool,nice kit but i need some thing with a complete down pipe.
Thanx for getting back to me any way bud.
Il be able to get it of you on Monday. I didn't make it in time to the bank before it close. Did you have the fse on yours. What were the out comes like.
Hi Scott, it has some piping but you may need a bit more to finish it off, it was on my car yes it was having proplems running lean witch it seemed to cure with a me adjustments (its has been adjusted to run well on a micra so you shouldnt have any problems! I dont think i have the fuel rail adaptor for it but they arnt very expensive mate :)
Let me know if you still interested
oooo super! i will be interested mate but not for a while yet as i havnt got the money :) if you can keep it aside for me that would be cool
