Morning all,
New to Micras but not new to tinkering with cars! Already had a good look around the forum and found some really useful info, thank you - it's a brilliant resource.
Anyway, I picked up a 1.0 K11 (2001, coil-on-plug version) Micra last week and been gradually going over it sorting a few bits. The car has done ~19,000 miles and still has 3 of the original tyres on it (new ones been ordered!), plus the original aux and alternator belts (now been swapped), and came with a free indoor swimming pool (now been drained).
It looks to have had reasonable use in the last few years (~6k miles in the last 2 years) but had been stood for a bit before I picked it up. Despite this it fired into life perfectly first time, ran beautifully, and subsequently did so for the next half a dozen times - but wasn't warmed up fully after doing so, so I assumed it had the 'cold flooding' issue.
I pulled the plugs out to find they were sopping wet, so left them out over the weekend. Battery is good (holding a solid 12.5v and cranks the engine nicely), I've fitted a new fuel filter (which is the right way round ), treated it to half a tank of V-Power, and it's been cranked quite a bit with the plugs out and fuel pump fuse pulled to prime the oil and fuel system (edit - just realised that won't be priming the fuel system then will it, ha! Perhaps it just needs more cranking to get fuel to the injectors). I also hoped this would get rid of some of the excess fuel in the cylinders.
The immobiliser light on the dash flashes as normal when ignition is turned off, with the ignition on and the car cranking it goes it - which I assume is normal.
I had soldered a resistor in parallel with the ECU water temp sensor to try and prevent the cold start problems in future, but in case this was cocking things up I have subsequently removed it to return things back to standard.
Trouble I'm having is that the little bugger won't start. As I've said it cranks well, and appears to be getting fuel (the new plugs have got wet too). I need to enlist the help of a friend to check for spark (the coil sticks are 'spring loaded' so the plugs fall out if you're not holding them in), but other than that I am out of ideas.
Anything else I should be checking?
Thanks in advance!
Adam
Thanks in advance!
Adam
