K11 Seat Hinge Trim Falling Off
FIXED: (SEE BELOW)
Has anyone got a better way to fasten the seat hinge trim on so that it doesnt keep falling off? The plastic clips used by nissan dont hold the trim on very well.
I was thinking of drilling a small hole in the trim and using a small screw grommet in the hole in the hinge and screwing the cover on through the hole i drilled. But thought id ask if theres a better way before i drill any holes.
FIXED:
I have fixed this issue. I cut a hole in the perpendicular plastic ridge on the back of the trim to get a cable tie through. Then I put the cable tie around the hinge and pulled it tight. If i need to get it off ever i can get a blade in to cut the cable tie. Hope this helps someone with the same issue.
